2003 Acura TL Alarm/RS Wiring
bxscig
Copper - Posts: 41
Posted: April 07, 2004 at 12:53 PM / IP Logged
Hi,
I am trying to install a car alarm system for auto open/close windows and sunroof.  I've tried searching but I didn't get any hits.  I need the 2003 Acura TL (Type S) wiring diagram.  If the 2003 TL Type S is not available I think it should be the same for 2002 and 2003 TL or TL Type S.  Any help would be greatly appreciated.
Thanks a lot!
boomer_106
Silver - Posts: 710
Posted: April 09, 2004 at 9:44 PM / IP Logged
Acura
3.2 CL & Type S
2001-2004
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK / YELLOW
IGNITION SWITCH HARNESS*
Ignition #2:
WHITE/ BLACK
Ignition  #3:
N/A
Accessory:
YELLOW
Brake  Light:
GREEN / WHITE (+) OR WHITE BLACK
SEE NOTE BELOW***
Tach  Signal:
BLUE
IN 2-PIN CONNECTOR NEAR PASS SHOCK TOWER
Parking Lights:
RED / BLACK (+)
DRIVER'S KICK, LEFT OF COLUMN OR SECURITY MODULE **
Headlights:
RED / YELLOW (+)
IN # PIN BROWN CONNECTOR IN DRIVER'S KICK PANEL
OEM Alarm  Disarm:
BLUE (-)
AT SECURITY MODULE **
OEM Alarm  Arm:
ARMS WITH LOCKS
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 * This vehicle is equipped with a transponder immobilizer system. Use Universal Alarm Bypass Module part # 2x402 where x equals any number. ** Security Module Is Located Underneath The Passenger Seat. *** Use GREEN / WHITE for 2001-2002, use WHITE/ Black for 2003.
Acura
3.2 CL & Type S
2001-2004
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
IGNITION SWTICH HARNESS
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
BLACK/ WHITE (-)
PASSENGER FUSE PANEL OR SECURITY MODULE
OEM Horn:
LT. GREEN/ BLUE (-)
STEERING COLUMN HARNESS
Power  Lock:
BLACK/ BLUE (-)
PASSENGER FUSE PANEL ***
Power  Unlock:
ORANGE (-)
Trunk  Release:
BLUE/RED (+) OR WHITE (+)
SEE NOTE BELOW**
Alarm  Input Wire:
BLACK/ WHITE (-)
Notes:
** BLU/RED (2001-2002) located at Security Module underneath the passenger seat, White (2003) locate behind the glove box in MUX module. *** See Installation Note #201 - Negative Pulse Door Locks Diagram. Alternate Wires Are RED / Yellow (-) For Lock And RED / Blue (-) For Unlock Located At The Security Module Underneath The Passenger Seat.
bxscig
Copper - Posts: 41
Posted: April 11, 2004 at 10:03 PM / IP Logged
Thanks for the reply.  Is the wiring for the CL and the TL the same???
