wire 2 kicker compVR CVR10-4
db's
Posted: April 12, 2004 at 10:40 PM / IP Logged
  Hi i need some help with my wiring on my suds. I have the 2 kicker comp 10 inch 4-ohm dual voice coil. How would i wire this???     I will be running the suds with amp Performance Tecknique ICBM-779 2channel 600w x 2ch.       The subs are mounted on a sealed box.  Also i would like to know if the sub would  be wired in parelle or in series, and if i sould run them at 4ohm or 8 ohm?
        Thank you db..
Ketel22
Silver - Posts: 976
Posted: April 12, 2004 at 10:52 PM / IP Logged
 you could run your voice coils in parallel series to the amp bridged to give the amp a 4ohm load and your rms out on the amp would be like 480wrms
wire 2 kicker compVR  CVR10-4 - Last Post -- posted image.
Quad L Handyman services
db's
Posted: April 12, 2004 at 11:08 PM / IP Logged
  Thank but i also have another question. On the back of the kicker subs it has 2 red one with a wite dot and one solid also with the back one with white dot and one solid wich one goes were?
db's
Posted: April 12, 2004 at 11:40 PM / IP Logged
  sorry i ment 2 positive connections but one has a white dot. And also with the negative connection one has a white dot. Do i connect red w/white dot to negative solid and grad white solid and black w/white dot to amp???
