front grill?
audiomechanic
Silver - Posts: 388
Posted: April 20, 2004 at 7:30 AM / IP Logged
you will want to clear it too.
defective
Silver - Posts: 642
Posted: April 20, 2004 at 8:56 AM / IP Logged
that is how you fix your existing bumber.... it should be perfectly fine.... don't worry about it...
spl_enterprise
Copper - Posts: 62
Posted: April 22, 2004 at 3:10 PM / IP Logged
its pretty easy to glass and not have bubbles. you also do not make a mold, the correct term if you want your piece to be solid is a "plug" you can make the plug out of anything like glass, foams, etc. you just lay aluminum foil inside of what you want to model, like your grille, then fill it with whatever matieral you decide to use, then you have your copy. hope this helps you.
Pete - SPL Enterprise Inc.
OHsolow
Member - Posts: 17
Posted: April 23, 2004 at 12:31 AM / IP Logged
i think i should practice more.....im thinking of a center console peice..to houuse a few guages ...radio...?
