how many relays needed for 4 actuators?
cambosoup99
Member - Posts: 8
Posted: April 17, 2004 at 10:15 PM / IP Logged
Hey guys was curious if the two relay setup for one actuator is enough to power 3 more actuators. I've done a search so far no luck. Will I need 2 relays for each actuator?? Appreciate the help in advance.
I purchased the DEI 451M, could i possibly use this to power all 4 actuators?
Bnluis
Silver - Posts: 578
Posted: April 17, 2004 at 10:50 PM / IP Logged
2 relays, yes u can use that to operate all four doors.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
CutDog504
Silver - Posts: 643
Posted: April 18, 2004 at 2:14 AM / IP Logged
Two relays wil be good enough to power all four actuators, yes. I've done it several times before. Just be sure to fuse it at 7.5 amps per actuator, which will be 30. Also, for the power and ground wiring to the relays, use no thinner than 14 guage.
Monday, August 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
