Tach Wire, 2003 WRX
fredisfound
Copper - Posts: 60
Posted: April 19, 2004 at 5:47 AM / IP Logged
Hi all, can anyone tell me where to find the tach wire on a 2003 subaru wrx,I have to put an autometer tacho in it but cannot locate the tach wire.The coil packs are located on the end of the spark plugs and it cant be hooked up in the normal way.Any help would be great..Thanks.
icacha
Member - Posts: 19
Posted: April 19, 2004 at 8:57 AM / IP Logged
Try this, but if not 100% sure ask how to test.
TACH SENSOR GREEN (AC) ECM below GLOVE BOX *2
TACH SENNOTES:
*1 - The Integrated Module is located to the left of the steering column.
*2 - On the turbo models the tach is in pin 9 of the 24 pin plug. The tach wire is also found behind the instrument cluster in the 10 pin plug.
