3 questions about box-building
alex75
Copper - Posts: 134
Posted: April 19, 2004 at 12:37 PM / IP Logged
I'm building a box for an Alpine Type R 12, not yet sure if going sealed or ported.
1. How do I calculate the volume of internal braces in a box?
2.  Does it matter if my sub faces up, or faces the rear trunk wall?
3.  Should I use sound dampening inside the box.  Polyfill, or dynamat etc.
defective
Silver - Posts: 642
Posted: April 19, 2004 at 1:02 PM / IP Logged
1. go here https://www.the12volt.com/caraudio/boxcalcs.asp
2. Depends on the car
3. if you need it...... dynamat is useless inside the box.... use it for the car
alex75
Copper - Posts: 134
Posted: April 19, 2004 at 2:21 PM / IP Logged
Concerning what direction the sub faces, I drive a Nissan Altima w a trunk.  Seats don't fold, but w/ the armrest down I have a 6 x 12 opening.  I'm very familiar w the volume calcs on this site, but it only calculates interior  volume, I need to know exterior volume of the internal braces.  The box is going to be square or rectangle, what determines the need for polyfill or other dampening material?
forbidden
Platinum - Posts: 5,354
Posted: April 19, 2004 at 2:47 PM / IP Logged
L x W x H = cu.ft.
12" x 12" x 12" = 1 cubic foot = 1728 cu.inches
A brace that is made out of 3/4" mdf may look like this
12 x .75 x 8 = 72 cu. inches or .042 cu.ft.
If you have built your box to the internal specs as indicated, you will need to modify either the L,W or H to add the space taken up by the brace. Thus if you needed and calculated out 2.0 cu.ft, you will now have to change one value to get 2.042 cu ft. Now if you are an anal box builder (like some of us) or a die hard competitor then this will matter. If this is a sealed box, it would more than likely not make a difference at all. You can be out by about 1/4 to 1/3 total volume before it will begin to affect the performance of a sealed box.
alex75
Copper - Posts: 134
Posted: April 20, 2004 at 9:32 AM / IP Logged
Muchas Gracias my Amigo!  I divide the cu inches by 1728 to get cu ft., correct?  For example a brace that is 13x2x2=52 cu in, 52 divided by 1728=.030 cu. ft?  And to think I laughed when my math teacher told me I would use this someday!!  thanks again.
forbidden
Posted: April 20, 2004 at 12:33 PM / IP Logged
And my friends laughed at me when I went back to school to get my Algebra 12, 6 years after highschool. Guess what else, you also need to know how to sew. Two things that I never thought I would use in my life.
