2002 nissan quest
Welcome Guest :)
jaurora
Silver -
Posted: May 07, 2004 at 2:58 PM / IP Logged
Does anybody have the wiring chart for a 2002 nissan quest? Im doing an install on it this weekend.
Thankyou
Jeremy
MECP certified (If it really means anything)
Jeremy
unreal3z
Member -
Posted: May 07, 2004 at 5:52 PM / IP Logged
is it for radio, alarm, or what?
rudbwoy69camaro
Silver -
Posted: May 08, 2004 at 10:28 AM / IP Logged
2002 Nissan Quest | Item | Wire Color | Polarity | Wire Location |
| 12V | WHITE/ red | + | ignition harness |
| STARTER | BLACK / YELLOW | + | ignition harness |
| IGNITION | BLACK/ white | + | ignition harness |
| ACCESSORY | blue | + | ignition harness |
| SECOND ACCESSORY | none | | |
| TACHOMETER | white | | pin 2 @ PCM *2 |
| POWER LOCK | red | - | either door harness |
| POWER UNLOCK | RED / black *3 | - | either door harness |
| PARKING LIGHTS + | do NOT use | | |
| PARKING LIGHTS - | gray/red | | headlight switch |
| DOOR TRIGGER | *1 | - | *1 |
| HEADLIGHTS | yellow | - | headlight switch |
| WIPERS | blu/orn & brn/wht | - | wiper motor |
| LF WINDOW UP/DN | blu/red - purple | A | drivers window switch |
| RF WINDOW UP/DN | grn/blk - orange | A | drivers door harness |
| LR WINDOW UP/DN | RED / blk - RED / yel | A | drivers door harness |
| RR WINDOW UP/DN | orn/blu - red | A | drivers door harness |
| TRUNK/HATCH PIN | with door trigger | | |
| HOOD PIN | BLACK/ pink | - | harness behind fuse box |
| TRUNK/HATCH RELEASE | none | | |
| FACTORY ALARM ARM | arms with lock | | |
| FACTORY ALARM DISARM | disarms with unlock | | |
| HORN TRIGGER | lt. blue/black | - | steering column |
| BRAKE WIRE | yellow/black | + | brake pedal switch |
| LOCK MOTOR | GREEN/ YELLOW | | drivers door harness |
| UNLOCK MOTOR | WHITE/ green | | drivers door harness |
| DISARM DEFEAT | WHITE/ red | | passengers door harness |
| DISARM NO UNLOCK | *4 | | |
| DOME SUPERVISION | BROWN / white | - | low in drivers kick |
| SPEED SENSE | GREEN/ YELLOW | | pin 27 @ PCM *2 |
| SUN ROOF OPEN/CLOSE | not recommended | | |
| SUN ROOF LIMIT | none | | |
| LF SPEAKER | | | |
| RF SPEAKER | | | |
| LR SPEAKER | | | |
| RR SPEAKER | | | |
| RADIO 12V | BROWN / white | + | radio |
| RADIO GROUND | black | - | radio |
| RADIO SWITCH | orange | + | radio |
| RADIO ILLUMINATE | | | |
| POWER ANTENNA | none | | |
| Notes: | *1 Low in the drivers kick find red for the drivers door and RED / white for the liftgate. In the passengers kick find RED / white for the passenger front door, and RED / green for the sliding doors. Use all trigger wires and diode isolate each. *2 The PCM is located behind the glove box. *3 Unlock requires double pulse. *4 A single pulse on the unlock wire will disarm the factory alarm without unlocking. |
jaurora
Silver -
Posted: May 10, 2004 at 6:46 AM / IP Logged
rudbwoy69camaro You are the man!!
Thankyou
Jeremy
Tuesday, April 7, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
