04 santa fe hyundai
grundler1975
Member - Posts: 29
Posted: May 08, 2004 at 9:01 AM / IP Logged
i need a wiring diagram for a 2004 hyundai santa fe. R/S, keyless
rudbwoy69camaro
Silver - Posts: 350
Posted: May 08, 2004 at 10:32 AM / IP Logged
I have the 2003, couldn't find the 2004. check the wires out w/DMM.
12volts
red & orange
ignition harness
Starterblue + ignition harness
Second StarterN/A
Ignitionblue + ignition harness
Second Ignitionpink + ignition harness
Third IgnitionN/A
Accessorygreen + ignition harness
Second AccessoryN/A
Keysensebrown + ignition harness
Power Lockyellow - DKP, white 22 pin plug
Power UnlockWHITE/ black - DKP, white 22 pin plug
Lock Motorgray 5wiDKP, white 22 pin plug
Unlock Motorwhite 5wiDKP, white 22 pin plug
Parking Lights+GREEN/ orange + fuse box, 15 pin plug
Parking Lights-white - headlight switch
Hazardsgreen (only w/fac. alarm) - ETACS, 12 pin plug
Turn Signal(L)pink + steering column
Turn Signal(R)gray + steering column
Reverse Lightblue/black + fuse box, top right plug
Door Triggeryellow - fuse box, 8 pin plug
Dome Supervisionuse door trigger
Trunk/Hatch PinBLACK/ orange - fuse box, 15 pin plug
Hood Pinpink - ETACS, 12 pin plug
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armfactory remote only
Factory Alarm Disarmfactory remote only
Disarm No Unlockdisarms with remote start
TachometerWHITE/ black or blue ac ECM
Wait to startN/A
Brake WireGREEN/ black + brake pedal switch
Parking Brakegreen - parking brake switch
Horn Triggerbrown - steering column
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
Immobilizer Bypass Module
04 santa fe hyundai - Last Post -- posted image.
MAKE : HYUNDAI | MODEL : SANTA FE | YEAR : 2003
