Omega Comfort Start Problems
SoundFX411
Copper - Posts: 153
Posted: May 09, 2004 at 6:10 PM / IP Logged
I installed an Omega Comfort Start in a Toyota Sienna and the problem is that you have to put the transmitter right up to the antenna for it to work. Does anyone know of any ajustments for this system. I mounted the antenna high on the windshield and had poor response. I thought it was because of the sunglare strip across the top of the winshield. So I moved it to the corner below the strip and still no good. ANY HELP PLEASE!!
desh187
Copper - Posts: 310
Posted: May 09, 2004 at 9:38 PM / IP Logged
Poor range,could be a defective antennae.
draasch
Gold - Posts: 2,172
Posted: May 09, 2004 at 9:40 PM / IP Logged
check the wire to see if it has been damage during the install...
or call 1-800-554-4053 and pound out. ask for a tech to call you back....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
