How to run a wire from fuse box ?
andyhoiho
Member - Posts: 7
Posted: May 29, 2004 at 5:03 AM / IP Logged
HI !!!
i want to add a power mirror and power window to my 00 Civic Hatch, can anyone tell me how to run/wire a wire from the fuse box??
let say if i want to run a wire to the power mirror, and put the fuse into the fuse box, then how can i get/run/wire the wire for the 12volt(+)???
or the wire has already located under the fuse box???
please help me !!!
Thanks !!!!!!
auex
Platinum - Posts: 5,041
Posted: May 29, 2004 at 10:24 AM / IP Logged
You don't really run it into or through the fuse box. What you do is either run a wire from the battery to inside the vehicle, fused at the battery of course, or you tie into the main power wire at the ignition harness, again with a fuse.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
shnackelberry
Posted: June 02, 2004 at 12:40 AM / IP Logged
right in the fuse box you see the 3 places where you could plug on a slide on crimp connector, i would call it a speaker conn. 1 of those 3 will give you 12 volts ign. the other is parking lights, and the other is batt constant. use the one hot with key on. got it. look right at the fuse block youll see what im talking about.     cool
andyhoiho
Member - Posts: 7
Posted: June 02, 2004 at 1:08 AM / IP Logged
thanks bro. !!!
i will try to find it on weekend !!!!
thanks again !!!
