03 Dodge Ram Speed Sense
Yeahitsgotahemi
Posted: June 01, 2004 at 7:36 PM / IP Logged
Anyone know where the Speed sence wire is on a 2003 Dodge Ram 1500 Hemi
I was told the "White\Orange conn. 2, pin 27 @ PCM *5"
is the one, yet there is no white\orange wire from headlight to taillight on this truck, I also pulled the PCM apart and there is no connection on the White adapter on pin 27.
Any help would be great.
Thanks...
auex
Platinum - Posts: 5,041
Posted: June 01, 2004 at 8:22 PM / IP Logged
"On the 4.7L motor, the VSS is WHITE/ orange in conn. 1, pin 13. On the 5.7L motor, the VSS is dk. GREEN/ YELLOW in conn. 1, pin 13." for 2003.
"Speed Sense dk. GREEN/ YELLOW      PCM, black plug, pin 13. The PCM is on the passenger side firewall. On diesel models the vss wire is at the ECM on the lower driver side of the engine, 50 pin plug, pin 11." for 2004.
Courtesy of Directwire.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Yeahitsgotahemi
Posted: June 01, 2004 at 10:08 PM / IP Logged
Thanks AUEX, took me 20 minutes after your help.
Thanks for the correct and quick responce
Chris
auex
Yup.
