197 Ford F250
Vikerex
Member - Posts: 15
Posted: June 19, 2004 at 8:30 AM / IP Logged
I have installed a remote starter,  a Crime Stopper RS III, now a few questions:
The truck will not start on the first push of the remote, why?
What wires on the truck do I use to run the blower for the heat and AC (accessory)?
Any help is appreciated!!!!
Thanks in advance!!!!
Just gettin' Started :>)
Vikerex
Member - Posts: 15
Posted: June 19, 2004 at 8:38 AM / IP Logged
The topic is suppose to read: 1997 Ford F250, not 197 Ford F250
spl-Hz
Copper - Posts: 94
Posted: June 19, 2004 at 6:39 PM / IP Logged
The fact it even starts means you  might have most every hooked right. Chech owners manuel to see if program opions different botton pushs.  10 to 12 g  Gray / YELLOW wire in  Ing. harness . Might need step relay if your output is weak.
