Best Battery
llakhansingh
Member - Posts: 7
Posted: June 24, 2004 at 9:39 AM / IP Logged
I'm running a three amp system that needs at least 280amps,together with an ohio generator 250amp alternator and 4 optima yellowtops.Anyone knows of a better battery than optima for my use.
Clean Install
Silver - Posts: 446
Posted: June 24, 2004 at 12:10 PM / IP Logged
those a great batterys
If we learn from each success and
each failure, then we can improve ourselves
nollaz
Member - Posts: 44
Posted: June 24, 2004 at 1:18 PM / IP Logged
you are running the best batterys in my opinion
yup
dbdraggirl
Copper - Posts: 75
Posted: June 24, 2004 at 9:22 PM / IP Logged
Have you looked into the SVR Batteries? I have an SVR 75-12 900 CCA and it made the world of a difference... Good Luck
Girls can do anything guys can do!!
2~12" Kove Armageddon Z's
US Amps 2000x
US Amps 4300x (mids & highs)
US Amps X2R Crossover
Clarion DXZ745MP
2~Kove 5 1/4" KC Components
CompuStar Alarm :o)
speedwayaudio1
Silver - Posts: 879
Posted: June 25, 2004 at 12:53 AM / IP Logged
battcap makes a awsome 800cca batt thats half the size of a optima batt and it is sealed so you can install it any where.
Big Dave
$uperflame$
Member - Posts: 45
Posted: June 25, 2004 at 8:18 AM / IP Logged
http://www.batterymart.com/battery.mv?c=odyssey  these are realy the best ,even stinger buys them and putts ther name on them read about them,they got this big a$$ one coming out next month and im replacing my optima's with them, thers a reasson optimas are so light its because thers less plates inside one odyssey with put out twice as meny cca as a optima and wont wear out
mikedawg
Copper - Posts: 142
Posted: June 25, 2004 at 8:56 PM / IP Logged
i bought a svr battery and it just went in the crapper. it said i had bad cells so i got a yellow top and it made a bigger difference.
always looking for new info and willing to give it
djMINIoompa
Copper - Posts: 125
Posted: June 27, 2004 at 9:24 PM / IP Logged
IMO the yellow tops are the best out there
dbdraggirl
Copper - Posts: 75
Posted: June 28, 2004 at 8:03 AM / IP Logged
Ok, from what I know which in some cases might not be a whole lot but I do know that optimas are not all they are cracked out to be... Under the hood.. yeah maybe.. but.. in the trunk it's better to have a complete gel cell battery and optima is not that.. they are half gel half acid.. so... in buying an SVR or something of that sort you are getting a complete gel battery...
US Amps 2000x
Clarion DXZ745MP
CompuStar Alarm :o)
djMINIoompa
Copper - Posts: 125
Posted: June 28, 2004 at 9:19 AM / IP Logged
However those gel batteries do not have the recovery time of an optima. you can charge optimas at high voltage for shorter times and they are back to full capacity. The gel battery doesnt have the recovery time, life cyle, or even raw power of an optima. Optimas are surpior batteries under the hood and in the trunk.
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
