1995 Accord Door Panel
msoviak
Member - Posts: 8
Posted: September 09, 2002 at 3:26 PM / IP Logged
I was wondering how to take the door panels off, both front and back, of a 1995 Honda Accord.
go2pac
Copper - Posts: 179
Posted: September 09, 2002 at 5:34 PM / IP Logged
Depends if you have window cranks or power windows. Besides that, you probably have 2-4 screws to remove and the door handle needs to be release from the linkage. The lower part of the panel just snaps away from the door. When that is done, the top part of panel which hooks over the door needs to be lifted up and off.
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
Moderator - Posts: 12,488
Posted: September 10, 2002 at 12:22 AM / IP Logged
Don't forget those screws on the upper portion of the door handle and the side mirror cover needs to be removed as well.
msoviak
Member - Posts: 8
Posted: September 10, 2002 at 3:53 PM / IP Logged
I have power windows.  And thanks for the info. one last thing is it the same for the rear doors?
Posted: September 11, 2002 at 12:48 AM / IP Logged
Yes, rear doors have about 3 0r 4 screws ( by the handle, on the side and in the door handle release arm ). It will be held together by white plastic plugs..... pull from the bottom.
msoviak
Member - Posts: 8
Posted: September 11, 2002 at 12:29 PM / IP Logged
Thanks for all the help
Posted: September 11, 2002 at 12:38 PM / IP Logged
No problemo
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
