difference between '00 & 03 mustang
frogger42024
Member - Posts: 8
Posted: June 30, 2004 at 7:44 AM / IP Logged
Can anybody tell me if there is a difference between the '00 mustang wiring and the '03 mustang wiring for alarms?
jfk51502003
Copper - Posts: 221
Posted: July 01, 2004 at 2:29 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / MUSTANG / 2003 / Security
[PRINT THIS PAGE]
12voltsyellow & lt. GREEN/ purple + ignition harness
StarterWHITE/ pink + ignition harness
IgnitionRED / lt. green + ignition harness
Power Locklt. green + 20 pin plug, pin 20 at GEM
Notes: The GEM (Generic Electronic Module) is located above the driver kick panel.
Power Unlockpurple + 20 pin plug, pin 18 at GEM
Lock MotorRED / white 5wi20 pin plug, pin 9 at GEM
Unlock MotorRED / orange 5wi20 pin plug, pin 7 at GEM
Disarm Defeatpink/orange 5wi20 pin plug, pin 8 at GEM
Parking Lights+brown + 26 pin plug, pin 7 at GEM
Parking Lights-WHITE/ black - 26 pin plug, pin 11 at GEM
Hazardssame as turn signals
Turn Signal(L)lt grn/wht(F), lt grn/org(R) + steering column
Turn Signal(R)wht/lt blu(F), org/lt blu(R) + steering column
Door Triggeryel/black (L), gray/red (R) - 20P plg, pin 13 & 5 at GEM
Notes: Use yellow/black for the driver door trigger and gray/red for the passenger door. Use both wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information.
Dome SupervisionBLACK/ white + 20 pin plug, pin 3 at GEM
Trunk/Hatch PinBROWN / white - 12 pin plug, pin 3 at GEM
The hatch pin needs to be diode isolated from the GEM module. Refer to DirectFax document 1076 for wiring information.
Hood PinN/A
Trunk/Hatch Releasepink/lt. green - 26 pin plug, pin 25 at GEM
Power Sliding DoorN/A
Factory Alarm Armarms on lock with door open
Factory Alarm Disarmdk. GREEN/ purple - 20 pin plug, pin 16 at GEM
Disarm No Unlocksee factory alarm disarm
TachometerNOT red or WHITE/ lt. blue ac ignition coil or coil pack
Horn Triggeryellow/lt. green - 26 pin plug, pin 12 at GEM
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
difference between '00 & 03 mustang - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: PATSPart #: 555F, 556U, or 555U
Notes: N/A
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
