Midrange Driver Opinions / Suggestions
kfr01
Gold - Posts: 2,121
Posted: July 23, 2004 at 7:14 PM / IP Logged
Alright.  I won't be able to fit a large driver into the kicks.  4.5" or smaller would be perfect.  I am looking to spend under $300 for a pair.
Here are some options I'm considering:
http://www.dynaudio.com/eng/mobile/driver/md140-2.htm
Positives:  Very small.  Seems to be very high quality.
Negatives:  High crossover requirement 700hz is ideal, so I read.
http://www.mbquart.com/2003/en_US/products/prod_detail.asp?isArchive=&cat=auto&series=premium%20series&strt=1&model=PWE+100
Positives:  I can mount the quart tweet in the coax position.  Matches my other components.
Negatives:  Expensive for what it is.  Slightly larger than the Dyn.
http:///.com/dll?ViewItem&rd=1&item=5710851337&ssPageName=STRK:MEWA:IT
Positive:  This is my low cost alternative.  Probably a decent quality driver.  I can sell off the tweet and crossover to make this a really cheap 4".
Negative:  Probably doesn't match the quality of the other two.
I have no way to confirm the quality or listen to any of these speakers at local dealers.  Anyone have any thoughts or other suggestions? How would 4ohm home drivers from companies like vifa, seas, scan-speak, etc. match up?  Some of the Vifa drivers seem to have pretty flat responses at a low cost.
Thanks as always.
New Project: 2003 Pathfinder
customsuburb
Gold - Posts: 1,813
Posted: July 23, 2004 at 8:01 PM / IP Logged
Adding 4.5" mids to a component system with a 6.5" woofer seems like it would be overly complicated and not needed (the 6.5" woofers you already have can play alot lower then a 4.5" mid would, so how are you going to get the 6.5 woofer to not play the frequencys that the 4.5" mid would be playing?) Someone pleaseee correct me if I'm wrong.
xtreamcc
Silver - Posts: 467
Posted: July 23, 2004 at 8:04 PM / IP Logged
suburb is right, what are u gona need a 4.5" mid for if u have a 6.5"? Would be a waste of money and would potencially cause canclation..
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
kfr01
Gold - Posts: 2,121
Posted: July 23, 2004 at 10:08 PM / IP Logged
I'm not dumb - I won't be playing the same frequencies on both drivers.  They will all be properly crossed over.
I am interested in doing this for multiple reasons:   First, because the 6.5" quart sounds strained at the high end of the midrange.  I think 2500hz is slightly too high for the 6.5" quart driver.  Additionally, I feel like I can fix some of the imaging problems with kicks that my door midrange creates now.  Finally, the Eclipse provides 5 quasi-parametric settings for the mids, and 5 for the highs.  The quart tweeter's frequency response is flat.  I don't need the 5 parametric settings on it.  The quart 6.5" has a much sloppier response than I'd like it to have.  By narrowing the frequency range it needs to play I will be able to clean it up better with the eq.
It will be quite easy to get the 6.5" to not play the frequencies the 4" will play.  That isn't an issue.
Eclipse deck has 3 way crossover.
Sub - up to 80hz
6.5" 80 to 500 (or whatever I pick)
Quart crossover w/ 4" and tweeter connected:  500 up.
The quart crossover will handle the cross from the 4" to the tweet @ 2500hz.
Why am I doing this?  Because I want better sound.  If you can think of a better route short of replacing my current speakers, by all means, let me know.
/bump my original question.
DYohn
Platinum - Posts: 10,741
Posted: July 23, 2004 at 11:21 PM / IP Logged
Here, try a couple of THESE.  They are cheap, decent speakers made by a reputable company (made by Vifa for use in JBL home sudio systems) and this way you can try your setup and see if you can get the results you want without spending a ton.  Then, either keep them (as Vifa speakers sound pretty darn good) or if the power handling is too low, you can replace them with what you want or decide you need a different approach.  By the way, as much as I love Dynaudio drivers, those soft dome mids are probably not the best for your application as you will want something that has a bit more "throw" to it in a kick pod.
kfr01
Gold - Posts: 2,121
Posted: July 24, 2004 at 12:32 AM / IP Logged
Excellent.  Thanks DYohn.  Exactly the type of response I was looking for.  :-)
Anyone other opinions?
kfr01
Gold - Posts: 2,121
Posted: July 24, 2004 at 8:13 AM / IP Logged
Actually, DYohn, I have a follow up question for you, if you don't mind.
You've given me my perfect low cost alternative.  Now, if you had to choose ideal speaker for this application, what would you pick?
Thanks!
DYohn
Posted: July 24, 2004 at 9:38 AM / IP Logged
Wow, that's really hard to say.  I'd have to audition several before I could choose, as the mid to upper mids are where a LOT of musical information lives and the sound ot the midrange will largely determine the overall "feeling" of the sound in the application.  If I HAD to use 4.5" speakers, I'd probably start with the Scan Speak 12M series, as I already use Scan Speak for my mid-bass.  If it didn't sound right (or if it was too expensive) I'd try out raw driver offerings from Vifa, Audax, Morel, Davis, Dynaudio, and JBL.  If I didn't find any I really liked, I'd try out 4" or 4.5" component mids from Focal, Memphis, MB Quart, Infinity, Boston...  But then again I am very picky!
