cd player feedback
mood513doom
Posted: July 31, 2004 at 11:30 PM / IP Logged
I have A pioneer deh-p9600mp and when i turn it off and on all my speakers and my subs make a pop noise and it makes the noise yoiu hear when the cd player reads the disc and makes poping noise it did the same thing i figured out it was'nt my amps but it was my cd player so i put my new deh-p9600mp work fine for 2 days and when connecting my speakers to the correct channel on the amp and it started again, I put my brothers amp in did the same thing, checked the ground with jumper cables to the battery, checked the ground and power on the cd player with same method, I also installed another capacitor shortly after this problem started but i took it out and it still does the same. and when i connect my speakers to the cd player amp it does not do this but only when connected to the preamp outputs?
Doom
archemedes
Copper - Posts: 172
Posted: July 31, 2004 at 11:38 PM / IP Logged
try adding a relay to the remote turn on lead, alot of times that will eliminate the turn on and turn off pop (at least in my experience)
dudek38
Copper - Posts: 250
Posted: July 31, 2004 at 11:40 PM / IP Logged
lets talk more about your remote turn on wire. where is your turn on wire getting power from, the blue/white behind the hu, right?
owner of
Motion Marine & Car Audio
the florida keys
dudek38
Copper - Posts: 250
Posted: July 31, 2004 at 11:42 PM / IP Logged
archemedes, you have been one step ahead of me tonight.
owner of
the florida keys
mood513doom
Posted: August 01, 2004 at 12:40 AM / IP Logged
yes the blue and white, but the amps continue to pop and give feed back is there anything else i can use instead of the cd player remote wire to turn on the amp and test it
Doom
dudek38
Copper - Posts: 250
Posted: August 01, 2004 at 9:18 AM / IP Logged
you can use any low power 12volt source. try an ignition power from somewhere under the dash. but im not sure thats your problem. it definitely has something to do with the amp/s. has this amp always done this?
owner of
the florida keys
mood513doom
Posted: August 01, 2004 at 9:27 AM / IP Logged
I dont belive its the amps because i pulled my brothers car close to mine and hooked up my ams with his rca cables and my power,ground and remote and it sounds perfect
Doom
mood513doom
Posted: August 01, 2004 at 9:32 AM / IP Logged
i also just installed a second capacitor could that be the reason for this somehow?
Doom
