checking polarity
dirtylooks
Member - Posts: 24
Posted: August 03, 2004 at 10:24 PM / IP Logged
I wont to know if there is a tool that will check speaker wire that would tell u if   - or +...or  how would i check it ??? any info is welcomed
A way of life..
boomer_106
Silver - Posts: 710
Posted: August 03, 2004 at 10:30 PM / IP Logged
If you can see the speaker take a C or D size battery and take the wires coming from the speaker and hold one on top of the battery and one on bottom. If the speaker moves out away from the magnet you have the correct polarity. If it sucks in then you have the polarity reversed. The battery is marked + and -   on it if you look closely.
Charles_R_H
Copper - Posts: 122
Posted: August 04, 2004 at 11:12 AM / IP Logged
there are phase detectors out there if you want to spend $75 ++
or use a battery like boomer says
electronics run off of smoke, when you let the smoke out they stop working
Tcole
Copper - Posts: 92
Posted: August 04, 2004 at 1:42 PM / IP Logged
Cone moves outwards= positive lead to positive battery terminal, negative lead to negative terminal.
Cone moves inwards= positive lead to negative battery terminal, negative lead to positive battery terminal.
Hope that helps
