2002 Dodge Caravan Power Locks dont work Viper 550
Perfecto
Posted: September 17, 2002 at 10:31 PM / IP Logged
I had a Viper 550 ESP Installed in my new 2002 Dodge Grand Caravan Sport, by the book install, everything worked except the power locks jump back up after you lock them with the remote. It doesnt hapen all the time and more often after you lock, unlock, open a door, close and try to lock again. The locks jump up into the unlocked position. Have tried everything, need help please.
Platinum - Posts: 12,488
Posted: September 18, 2002 at 5:24 AM / IP Logged
Is the unlock wire broken anywhere that it's grounding out ? Chcek this connection again or check to make sure that the relay is not grounding out.
MadBanchee
Member - Posts: 8
Posted: September 23, 2002 at 6:53 PM / IP Logged
Check this out:
https://www.the12volt.com/doorlocks/page2.asp#dc
Except on a 2002 Caravan, the wire is purple w/ green and use 5.3k for the lock output and 2.0k for the unlock output.  Keep the resistors within ten percent of the value mentioned and also, be sure to have the diodes in series with each resistor to prevent any ground bounce.
Let us know what happens!
mbsaudio
Copper - Posts: 80
Posted: October 20, 2002 at 5:28 AM / IP Logged
I too am having trouble with a Dodge Caravan.  I can't seem to get the blower to work under remote start.  I checked many wire diagrams and see that one of the ign. wires required a 180 ohm relay which I've done.  There are only 5 or 6 small guage wires at the ign. switch.  One is 12v. constant, starter, ign1, ign2(with resistor).  The other couple don't seem to do anything under start so I left them alone.  Any help out there?
2002 Dodge Caravan Power Locks dont work Viper 550 - Last Post -- posted image.
Posted: October 20, 2002 at 8:37 AM / IP Logged
No second ignition.... two starter wires with the resistor inline attached through a relay.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
