Clutch bypass on 2000 Honda Prelude
vbel
Copper - Posts: 246
Posted: August 16, 2004 at 10:50 PM / IP Logged
What do I have to do to bypass the clutch to remotely start a 2000 Prelude? I'm hooking up Compustar alarm which has a remote start.
Platinum - Posts: 12,488
Posted: August 16, 2004 at 11:01 PM / IP Logged
Most Honda's are (-) trigger ( BLUE/BLACK at the clutch ).
vbel
Copper - Posts: 246
Posted: August 16, 2004 at 11:03 PM / IP Logged
Yes, but how do I hook it all up? Do I need a relay?
profuse007
Gold - Posts: 2,015
Posted: August 17, 2004 at 1:38 PM / IP Logged
yes you need a relay
85-(-)input while RStarting
86-12volt fuse constant
30-input ground
87-output ground to clutch wire
Houston,TX
lilboi
Copper - Posts: 126
Posted: August 17, 2004 at 2:37 PM / IP Logged
It worked for me. I have a 93 prelude. Make sure never to start it in gear. I tried that once (on purpose), with me sitting in the car. The car inches forward. And if you're a block away, you can stop it from hitting someone, or going into traffic.
vbel
Copper - Posts: 246
Posted: August 17, 2004 at 4:16 PM / IP Logged
It's a compustar alarm, and has a safety feature, so I don't think it will ever start in gear, but thanks for warning me anyway :)
profuse007
Thanks for the wiring info. It looks pretty simple :)
