2004 MDX alarm wiring
podolgq1
Posted: August 27, 2004 at 9:22 AM / IP Logged
Hello, can anyone help out with a wiring diagram/description for an alarm install (2004 MDX)
Platinum - Posts: 12,488
Posted: August 27, 2004 at 10:10 AM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=32255&KW=2004+Acura+MDX
12volts
white
ignition harness
StarterBLACK/ white + ignition harness
Second StarterN/A
IgnitionBLACK / YELLOW + ignition harness
Second Ignitionyellow + ignition harness
Third IgnitionN/A
AccessoryWHITE/ black + ignition harness
Second AccessoryN/A
Keysense
Power LockBLACK/ orange - passenger MUX unit
Power Unlockblue/orange - passenger MUX unit
Lock MotorWHITE/ red 5wipassenger MUX unit
Unlock Motoryellow 5wipassenger MUX unit
Parking Lights+RED / black + driver kick panel
Parking Lights-RED / yellow - headlight switch
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door TriggerBLACK/ white - interior light switch
Dome Supervision
Trunk/Hatch Pincommon with door trigger
Hood Pinyellow - hood switch or
Trunk/Hatch Release
Power Sliding DoorN/A
Factory Alarm Armblue/white - driver lock key cylinder
Factory Alarm DisarmBLACK/ red to blue - driver lock key cylinder
Disarm No Unlocksee factory alarm disarm
Tachometerblue ac test connector
Wait to startN/A
Brake WireWHITE/ black + brake pedal switch
Parking Brake
Horn Triggerlt. GREEN/ blue - steering column
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
