What type of resin to use?
masterwacker
Member - Posts: 15
Posted: September 04, 2004 at 8:05 PM / IP Logged
All right, I have my center console built (out of 1lb. foam and mdf) and wrapped in 100% polyester fleece.  It is ready to be glassed.  I went to the store yesterday to get the resin and the mat and they had two types of resin.  They had polyester resin and epoxy resin, and since glassing the console is not a right now need I decided to ask you guys a couple questions:
1)What is the difference between polyester and epoxy resin?
2)As to what resin I should use is it as obvious that since I have the console wrapped in polyseter fleece that I need to use polyester resin?  Or should I use epoxy resin?
Eat, Sleep, and Off-Road. Everything else is meaningless details.
Alpine Guy
Platinum - Posts: 2,478
Posted: September 04, 2004 at 8:08 PM / IP Logged
You should use polyester resin, , im not shure of the difference between the two tho.
auex
Platinum - Posts: 5,041
Posted: September 04, 2004 at 8:21 PM / IP Logged
Polyester for fiberglass, epoxy for kevlar.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
masterwacker
Member - Posts: 15
Posted: September 04, 2004 at 11:48 PM / IP Logged
Thanks guys.
