Adding Voice Feedback to Accessories
javageek
Member - Posts: 11
Posted: September 08, 2004 at 9:12 AM / IP Logged
Ok, this may sound trivial to some people, but I would like to add voice feedback to a couple of accessories. This will fall into the WBIC (Why? Because I Can) category. I would like it to play a voice when I switch on an accessory. For example, when I arm Nitrous I would like it to say "Nitrous Armed" in the interior of the car. What is the best way to go about doing this mod?
dxav
Silver - Posts: 314
Posted: September 08, 2004 at 1:04 PM / IP Logged
You can use a voice recorder chip (similar to the non-cassette type answering machines) that can record your own voice. Or you can download (probably serially [SPI, I2C protocol]) a digitized voice from free software that generates voices directly. I don't remember the exact part, but digikey.com may have it. I don't know if there is another simple way to do it.
But then you would need the IC to output to a small speaker under cirtain conditions. For example, 1 pin on the IC would 'listen' for an input (i.e. a hi input -- signaling you flipped a switch) then outputing an addressed line to the speaker. You may need additional combinational logic or a mux depending on how many different outputs you are looking for. But remember, for each 'voice command', you will need to know it's size, and how many data registers it would consume.
A microcontroller would help alleviate all this addressing.
That may have been too complicated, but that is all I can think of.
I hope an easier way surfaces, if I think of one, I will post again.
Good Luck,
DXAV
dxav
Silver - Posts: 314
Posted: September 08, 2004 at 1:37 PM / IP Logged
Check out digikey for ISD1200 Series voice chips. Up to 80 addressable blocks, and up to 12 sec records. Preamps, and ADC/DAC all handled within. Also has pushbutton playback (for your switch application). $5 for the chip, and only a little extra support circuitry.
Good idea, everyone, or no?
DXAV
javageek
Member - Posts: 11
Posted: September 13, 2004 at 7:20 AM / IP Logged
So with one chip I can have 80 different phrases?
dxav
Silver - Posts: 314
Posted: September 13, 2004 at 9:05 AM / IP Logged
Sorry for such a convoluted answer. But, basically you can. Just check the PDF documentation, with your username, I will assume you know about coding and addressing memory.
Good luck,
DXAV
javageek
Member - Posts: 11
Posted: September 13, 2004 at 2:09 PM / IP Logged
No, I don't know anything about programming. Think Coffee and Computer Geek. :)
javageek
Member - Posts: 11
Posted: September 13, 2004 at 3:34 PM / IP Logged
I found a link with schematics on how to build your own recorder and playback unit. This should be easy enough to incorporate into mobile audio. In case anyone is curious, here is the link.
http://www.scary-terry.com/dsr/dsr.htm
dxav
Silver - Posts: 314
Posted: September 14, 2004 at 7:12 AM / IP Logged
Yeah, that is basically the same chip I mentioned earlier. Are you going to try using it?
Good luck,
DXAV
