lack of sound
gbabyyyyy
Member - Posts: 9
Posted: September 10, 2004 at 9:20 PM / IP Logged
i put in two 12" subs and everything is hooked up correctly im pretty sure...but when i play music the subs are barely putting out any power...i thought maybe because my speaker wire is too small or something...help me out so i can listen to the full potential of my subs
go big or go home
auex
Platinum - Posts: 5,041
Posted: September 10, 2004 at 9:22 PM / IP Logged
Have you checked the phase of your subs? Unhook one and see if it gets louder.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
forbidden
Platinum - Posts: 5,353
Posted: September 10, 2004 at 9:24 PM / IP Logged
Sounds like that's the problem to me as well. If it is louder with the one sub playing, reverse the speaker leads from the disconnected sub and reconnect them. This should make the bass much louder again.
jeffchilcott
Platinum - Posts: 2,483
Posted: September 11, 2004 at 11:14 AM / IP Logged
what kind of subs what kind of amps...sounds like one sub out of phase but more info would help as well
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
robb420in323
Copper - Posts: 101
Posted: September 12, 2004 at 3:48 PM / IP Logged
Also  Check your gains.. also check that your not using the "RCA outputs" on the amp..
Hunter S. Thompson for sheriff
gbabyyyyy
Member - Posts: 9
Posted: September 12, 2004 at 6:46 PM / IP Logged
thanks for the help but it was just a bad amp...i switched it with my friends and everything worked so now i have to buy a new amp...what should I get? my subs are 1400W but i dont know what make because i bought them off a chinese guy and they are inside the box and i dont want to take it apart
go big or go home
pimpincavy
Silver - Posts: 880
Posted: September 12, 2004 at 7:48 PM / IP Logged
Did you buy this from a chinese guy at a flea market by any chance? I seriously doubt whatever you have can handle 1400W. They are probably Exploders, or Lanzers, or Audiopipe, or some other generic flea market sub. They must be in a bandpass box or something if you cant see the subs. Please tell me I am mistaken in my assumptions lol.
Ravendarat
Platinum - Posts: 2,806
Posted: September 12, 2004 at 9:20 PM / IP Logged
Are you 100 percent sure your amp is screwed and that it just wasnt hooked up outta phase before and when you hooked up your friends amp you just hooked them up correctly?
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
