Enclosed vs open
hopesfall
Member - Posts: 11
Posted: September 12, 2004 at 6:15 PM / IP Logged
What is the difference if I put a 12 inside an enclosed box, rather than putting it inside a box that exposes only the frame and dust cap?
/r7
Silver - Posts: 340
Posted: September 12, 2004 at 6:21 PM / IP Logged
are you saying invert your subwoofer in a box so the back of it sticks out, or are you implying a box with no walls and just a frame structure?
if its 1. then nothing changes
if its 2. subwoofers require an enclosure, unless they are specifically a 'free-air' subwoofer, but i havent seen any to my knowledge.
if its neither, please explain a bit more clearly.
in any case, i would stick a 12" in a sealed enclosure because it suits my music taste better
hopesfall
Member - Posts: 11
Posted: September 12, 2004 at 6:27 PM / IP Logged
I heard someone call it a bandpass, but im not sure thats what they were talking about. Its completely covered in a box, you can look inside the plexiglass to see it.
pimpincavy
Silver - Posts: 880
Posted: September 12, 2004 at 8:05 PM / IP Logged
Bandpass boxes are often used by lower end companies, like audiobahn, dual, boss, etc. To make their subs seem more appealing. Bandpass boxes are made to hit hard at a certin Hz level (ex. 30Hz). This means the sound you get from the subs is loud, but not very accurate. So you can kiss sound quality goodbye. I (and most people on this site) would not recommend putting your subs in a bandpass box, if you want SPL, use a ported box, if you want SQ, use a sealed box.
