JVC RF CD Changer, 2004 Ford Taurus
ancho15
Posted: September 14, 2004 at 6:37 PM / IP Logged
Hi I am really begging for help here.  This is a very basic question...
I just received my JVC chx 1500rf  cd changer and want to install it on my 2004 Ford Taurus SES.  I was wondering if anyone would give me some basics on how to do this.  There are three cables I have to plug in....Red (12 v power)  Yellow (memory) and Black (Ground).  I looked down in the accessory box and where the fuses are and have no clue as to where I should plug them in.  I have installed a stereo before but never a cd changer...I have no idea where to plug these in.. Please help... Thank you for you help.
angel
mobile1
Silver - Posts: 479
Posted: September 14, 2004 at 11:51 PM / IP Logged
you don't plug them in anywhere. you need to tap into a constant power source, a switched power source and a ground. My reccommendation is that you take it somewhere to get it installed professionally. ask the installers if you can watch them do it. this way you'll learn and not potentially ruin your car.
ancho15
Posted: September 15, 2004 at 1:07 AM / IP Logged
Please disregard!!  I found the power source in the trunk...now I just need to figure out how to plug in the cd changer into that source......please read my other post about Ford....cd changer
harvey1959
Copper - Posts: 94
Posted: September 15, 2004 at 6:15 AM / IP Logged
You can plug the red wire to the radio fuse, the yellow wire to cigarette lighter or horn fuse. (This is always on). Find a bolt under the dash board and tie the black wire under the bolt.  Scrape any paint away from the bolt.  That's the easiest way.
Harv
harvey1959
Copper - Posts: 94
Posted: September 15, 2004 at 6:19 AM / IP Logged
One other thing.  If this comes with a black box, remove the antenna jack from the back of the radio and plug that into the hole in the box (antenna input).  Plug the antenna out from the black box to the back of the radio.  Tune your radio to 89.1 fm.  Once you have your wires hooked up you should hear the CD through 89.1.
Harv
mobile1
Silver - Posts: 479
Posted: September 15, 2004 at 8:29 AM / IP Logged
this vehicle does need antenna adaptors as well. its not a standard antenna connection.
ancho15
Posted: September 15, 2004 at 2:34 PM / IP Logged
Update:
I found the radio box in the trunk to the left and found which cable has a direct power line.....I can't figure out which one is the ACC cable...........I turned on the car and then checked each wire but none of them showed power...only the direct power source (Red with Yellow)   Where can I find the ACC wire for Memory???
Also......what can I use to tap into this power source and is that recommended...having two things run on same wire???  Please reply asap.  Thank a lot!
Angel
Ford Taurus 2004 SES
stevdart
Platinum - Posts: 5,816
Posted: September 15, 2004 at 7:09 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=39159&PN=2
See the above posted yesterday.  Strip and solder your wire connections, then wrap well with electrical tape.  You can run two of the loads you are using on that 12v power source wire.
