grounding distribution blocks
Hoot
Member - Posts: 10
Posted: September 16, 2004 at 4:56 PM / IP Logged
I'm wiring up a ton of accessories in a public-service type install. (strobes, led's, siren, radios, etc...) I've got aftermarket fuse panels that will power everything just fine. The problem is trying to ground everything. It's not an audio type install where you just need to ground a couple of heavy gauge wires with a distribution block. I'll need to ground maybe a dozen or so smaller gauge wires with little ring terminals on the ends.
Is there any type of distribution block or barrier strip I can use that has at least 10 or 12 inputs and have a good size (at least 4 ga) grounding cable attachment point?
A place to buy online would be best.
ice4life8269
Copper - Posts: 112
Posted: September 17, 2004 at 10:19 AM / IP Logged
i know what you need. you need a bus bar, that will work the best for what you are doing. here's a link cuz i'm a nice guy: http://www.bertholdelectric.com/gusBerthold/groundBus_coGroundBar.asp grounding distribution blocks - Last Post -- posted image. good luck man!
mobilevt
Copper - Posts: 73
Posted: September 18, 2004 at 12:15 AM / IP Logged
Hoot,
I'm in this same type of business.  Generally, I use a 1 1/2" all thread 1/4 x 20 bolt on a carpeted base where the equipment are mounted on.  Bolt them on with the bolt & nut then put your ground terminals on them.
Sean
Emergency Vehicle Technician
Got Freedom? Thank a vet!
