Omega RS-7K2
playboyiscool75
Posted: October 07, 2004 at 10:48 PM / IP Logged
Sorry, I think I posted my other topic in the wrong forum, so please forgive if double posting.
I installed an Omega RS-7K2 keyless entry & Remote starter in a 2003 Buick Century. The problem I am having is bypassing the vats security system. I am trying to do the bypass with a PLXR bypass module. On the PLXR it states that the brown wire from the PLXR is suppose to attch to (-) Out when running from car starter. I am confused, what does (-)out mean?I am using the green wire "500mA Negative ignition Output" wire from the Remote start to the brown wire on the PLXR. Is this correct, can I hook them up direct or do I need a realay there to put 12volts+ to the PLXR. Sorry I am a newbie to all of this and the (-) input and (-) output is confusing me. So if any one has some information for me and a wiring diagram for a 2003 Buick Century all help would be greatly appreciated.
draasch
Gold - Posts: 2,172
Posted: October 07, 2004 at 11:38 PM / IP Logged
i dont se that wire that you are talking about....the green one.....i see the green glow plug wire....
what that means is that the wire you are looking for will show a negitive output when the car is running ( when the remote is used to start the car)
your satellite port should have the wire you need....
see if your install manual give you a breakdown of the pins....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
