Wiring diagram 04 mitsu lancer
Garcia_209
Member - Posts: 11
Posted: October 17, 2004 at 6:54 PM / IP Logged
i was wondering if anyone had a wiring diagram for a 04 Mitsubishi lancer oz-rally ??
Garcia_209
mo12v
Posted: October 17, 2004 at 7:02 PM / IP Logged
This is what I have:
Constant 12 voltsWHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ WHITEIGNITION SWITCH HARNESS
StarterBLACK / YELLOWIGNITION SWITCH HARNESS
Dome LightWHITE (-)WHITE CONNECTOR BOTTOM OF FUSE BOX
Trunk Pin SwitchGREEN/ ORANGE (-)LIGHT IN TRUNK
Parking LampGREEN / WHITE (+)WHITE CONNECTOR BOTTOM OF FUSE BOX
Power LockPURPLEDRIVER KICK PANEL
Power UnlockLT GREENDRIVER KICK PANEL
Negative Pulse Door Locks
Accessories
Window Up
Window Down
Ign Key Warn
Trunk Release
OEM HornBLUE/RED (-)STEERING COLUMN
Headlights
OEM Alarm Arm
OEM Alarm Disarm
Remote Start
Tach SignalORANGE @ IGNITOR # 1CYLINDER
Ignition #2BLUE/BLACKIGNITION SWITCH HARNESS
Ignition #3
Accessory
Neutral Safety
Brake LightGREEN (+)AT SWITCH ABOVE PEDAL
Reverse Light
Rear Window Defrost
Only Evolution VIII Models Have Been Shown To Have An Immobilizer.
MO
Garcia_209
Member - Posts: 11
Posted: October 18, 2004 at 12:40 AM / IP Logged
Thank you very much for your quick response
Garcia_209
