Quick Amp Question
Sharp21
Member - Posts: 41
Posted: October 30, 2004 at 10:59 AM / IP Logged
may seem stupid but here goes.
i hook the power wire to the positive terminal on the battery, then connect to the amp.
from the amp, i run a ground wire to an appropriate spot on the car.
Do i need to run a wire from the Negative battery terminal to a point on the frame, or somewhere in the engine bay?  or will the ground wire from the amp be enough.
i ask because i havent messed with stereos in about 7 years & the last time i did, my car kept dying until i grounded the battery, but everything im reading lately doesnt mention it.
Asmodeus
Silver - Posts: 393
Posted: October 30, 2004 at 11:03 AM / IP Logged
Upgrading the ground under the hood wont hurt you...It will only help...
Most of the time just grounding the amp to the car will be sufficient enough but grounding the battery to the car better wouldnt hurt, although its not necesary
Quick Amp Question - Last Post -- posted image.
Making the World A Louder Place
