Add extra 12vdc accessory outlet in veh.
indy1
Posted: November 05, 2004 at 12:44 AM / IP Logged
I would like to have a extra 12vdc accessory outlet for the trunk of my car.  Veh. 1999 & 2001 Ford tarus.  Any Suggestions?
info in indy
indy1
Posted: November 05, 2004 at 12:51 AM / IP Logged
The extra 12vdc accessory outlet will be for my extra cell phone.  Do I still need to run a wire direct from the battery?
info in indy
kidtransam
Copper - Posts: 99
Posted: November 07, 2004 at 6:07 PM / IP Logged
you dont have to run a wire direct from the battery.
Simply grab one from the radio harness..or better yet grab one from under the steering column (ign harness)
If you want it to be on all the time...grab the constant 12+ wire..if you want it to be on when the vehicle is running...grab the switched wire (ignition
Ignition harness: (recommended)
12+ constant =Yellow or Light GREEN/ Purple
switched (ignition) =RED / Light Green
Radio harness
12+ constant =GREEN/ YELLOW
switched (ignition) =Yellow/Black
for ground, just use a self tapping screw and screw it to a good close spot.
With a torch and a big enough hammer...it WILL friggin fit!!
audiopro111
Copper - Posts: 160
Posted: November 08, 2004 at 1:27 AM / IP Logged
kidtransam said everything i would of said so there's your answer.
AudioPro111
fatgotti
Copper - Posts: 177
Posted: November 10, 2004 at 12:17 PM / IP Logged
TO add to what kidtransam said if it is easier just tap into the power from current cig. lighter.
Fatgotti    Yeah my name is John and I am FAT!! YEAH BABY
