hook up wire sources
copcarguy
Copper - Posts: 122
Posted: November 10, 2004 at 4:21 PM / IP Logged
We have recently lost our supplier of automotive hook up wire and I need some new resources. Any contacts would be much appreciated!
We typically use 14ga. 12ga. 10ga. 8ga. wire if that helps at all
Thanks,
Rob
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
Platinum - Posts: 12,488
Posted: November 10, 2004 at 4:39 PM / IP Logged
Hey Rob, call up Albert at Ace distributing. He supplies us with some great products for little $$. His number is 1-800-701-6264 EXT 213 . Just tell him Jeff from Velocity in Canada sent you and he will require the business tax ID # from you as well as some references.
copcarguy
Copper - Posts: 122
Posted: November 11, 2004 at 11:51 AM / IP Logged
Thanks Jeff! I will call him this afternoon. Hard to loose a good supplier so I appreciate the info.
Robhook up wire sources - Last Post -- posted image.
R Jackson
Owner/Installer
copcarguy
Copper - Posts: 122
Posted: November 11, 2004 at 5:09 PM / IP Logged
Jeff,
I spoke with Albert, he cannot supply 12 or 14ga. wire. Any other ideas? I'll wait to hear from you. Thanks for the help!
Rob
R Jackson
Owner/Installer
dxav
Silver - Posts: 314
Posted: November 12, 2004 at 8:14 AM / IP Logged
Albert doesn't have that size wire? He used to.
You can check with Metra Electronics. I usually speak to Charlie (NY Rep). I use their Tsunami wire often now, and it is great. Prices are fair, though ACE most of the time can't be beat. They can ship from several locations, too.
They have several different grades, and various sizes.
DXAV
copcarguy
Copper - Posts: 122
Posted: November 15, 2004 at 8:35 AM / IP Logged
Albert said he doesn't carry anything in 12 or 14ga. I will try charlie and let you know how I make out.
rob
R Jackson
Owner/Installer
