2002 Chevy S10 Door wires
snmtazz
Member - Posts: 9
Posted: November 25, 2004 at 9:14 PM / IP Logged
There is a locked plug inside the door panel. Can anyone give me the wire description by color??
Got a hayes book and no luck.
rudbwoy69camaro
Silver - Posts: 350
Posted: November 27, 2004 at 3:43 PM / IP Logged
2002 Chevrolet S-10 Pickup
ItemWire ColorPolarityWire Location
12Vred+ignition harness
STARTERyellow+ignition harness
IGNITIONpink+ignition harness
ACCESSORYorange+ignition harness
SECOND ACCESSORYwhite+ignition harness
TACHOMETERwhitePCM *3
POWER LOCKlt. blue+brown plug at BCM *1
POWER UNLOCKwhite+brown plug at BCM *1
PARKING LIGHTS +brownlt. blue plug at BCM *1
PARKING LIGHTS -white *4lt. blue plug at BCM *1
DOOR TRIGGER*2-BCM *1
HEADLIGHTSPURPLE / white-purple plug at BCM *1
WIPERSnone
LF WINDOW UP/DNblue - brownAdriver window switch
RF WINDOW UP/DNlt. blue - tanAdriver kick, door harness
LR WINDOW UP/DNgreen - purpleAdriver kick, door harness
RR WINDOW UP/DNlt. green - purpleAdriver kick, door harness
TRUNK/HATCH PINnone
HOOD PINnone
TRUNK/HATCH RELEASEnone
FACTORY ALARM ARMnone
FACTORY ALARM DISARMlt.green-purple plug at BCM *1
HORN TRIGGERblack-steering column *5
BRAKE WIREwhite+steering column
LOCK MOTORgraydrivers kick panel
UNLOCK MOTORtandrivers kick panel
DISARM DEFEATtanpassengers kick panel
DISARM NO UNLOCKnonenonnone
DOME SUPERVISIONnonenonnone
SPEED SENSEnonenonnone
SUN ROOF OPEN/CLOSEnonenonnone
SUN ROOF LIMITnonenonnone
LF SPEAKERnonenonnone
RF SPEAKERnonenonnone
LR SPEAKERnonenonnone
RR SPEAKERnonenonnone
RADIO 12Vnonenonnone
RADIO GROUNDnonenonnone
RADIO SWITCHnonenonnone
RADIO ILLUMINATEnonenonnone
POWER ANTENNAnonenonnone
Notes:NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The BCM is located to the right of the accelerator pedal below the radio. The plugs on the BCM face towards the drivers side. *2 Use tan for the drivers door located in pin B4 of the purple plug, orange for the passenger door located in pin B2 of the purple plug, must diode isolate these wires. *3 The PCM is located on the passenger fender. On the 2.2L the wire is in a black 80 pin plug pin 10, and on the 4.3L the wire is in a red 32 pin plug pin 20. *4 This wire will not test when using the headlight switch. This wire is triggered by the DRL system. To meter the wire, start the car with the parking brake set, when the brake is released this wire will go to ground. *5 Also found in the brown plug at the BCM on vehicles with a factory alarm.
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
