555f or 555u/556u
massivegrk
Member - Posts: 38
Posted: December 17, 2004 at 6:05 PM / IP Logged
Which one would you go with for a 2002 Toyota Camry.  Read a lot of people having problems with the 555f on fords.  Is it the same on Toyota's?  Are the 555f's really bad in the winter, like someone posted?  Thanks
massivegrk
Member - Posts: 38
Posted: December 17, 2004 at 6:20 PM / IP Logged
also do i need 2 keys for a toyota, like you do a ford?
Frazyaf14
Posted: December 17, 2004 at 7:46 PM / IP Logged
You should only need one key for the bypass, and the other to use the vehicle, I personally think the 556u is easiest to work with
massivegrk
Member - Posts: 38
Posted: December 17, 2004 at 8:21 PM / IP Logged
well doesn't matter that the 555f has to be programmed.. like how it doesn't require a key be kept in it. Just wnted to know if i need 2 keys to program the bypass like fords do
kgerry
Platinum - Posts: 3,455
Posted: December 18, 2004 at 10:10 AM / IP Logged
yes you need both keys, just like the 555C
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
vinman75
Copper - Posts: 63
Posted: December 18, 2004 at 11:08 PM / IP Logged
I stay away from the 555F if the little pill moves at all then your car won't autostart. Or if it fogs up from really cold temps. I would go with 556U slap a key in it hide it in the dash real good and forget about it.
Haku
Copper - Posts: 204
Posted: December 19, 2004 at 6:38 PM / IP Logged
Go with a PKT, easier to install, fool proof in the cold, and no key required, and only one key needed to program it.
Hak
Siemens Autostart
massivegrk
Member - Posts: 38
Posted: December 20, 2004 at 1:55 AM / IP Logged
do you have a link for that PKT?
Haku
Copper - Posts: 204
Posted: December 20, 2004 at 8:13 AM / IP Logged
http://www.bypasskit.com/product.aspx?prodid=PKT
Hak
Siemens Autostart
massivegrk
Member - Posts: 38
Posted: December 20, 2004 at 10:18 AM / IP Logged
Thanks.. How do these connect to the RS and vehicle.. is there a ring like the 556u or a pellet like the 555f or does it connect directly to the immobilizer?  If it connects to the immobilizer where will I find the immobilizer in the car?  Thanks
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
