96 Buick Regal pink wire
blaube
Member - Posts: 17
Posted: December 25, 2004 at 4:12 PM / IP Logged
I am wiring up a Stinger SR200 solinoid. Stinger says to wire to a true ignition source.  The car audio manager at the store I work at says to tap into the pink ignition wire. Well, I crawled under the dash and found 4 pink wires comming from the steering column. Two were fat and two were smaller.  Which one is it?
-Brent
Platinum - Posts: 12,488
Posted: December 25, 2004 at 11:05 PM / IP Logged
Use a light tester or DMM to test for this wire. Should have 12 volts on it when you turn the ignition over 2 spots to the RUN position.
blaube
Member - Posts: 17
Posted: December 26, 2004 at 4:27 AM / IP Logged
Thanks for the quick reply. I decided to whip out my multimeter and find which one has 12 volts with the key on. Found it. Then I decided find which wire to use to wardwire my head unit to swithed 12volts under the center console. It appeared to be the yellow one. I then looked for the power antenna wire. It appeared to be the dark green wire. Wired everything up. Stereo worked fine except for the power antenna did not work. Turned off stereo and removed keys from ignition. Ran temporary wire to antenna to see if the connection was bad. Stereo did not come on this time. Disconnected stereo wire harness from deck. Noticed the lights were a bit low so I decided to start the car to get a guick charge and POOF!!, a cloud of smoke came from just behind the engine side of the firewall at about center position.
I can not find what I fried. All fuses are good. I cannot find any fuseable links anywhere. None of the wiring appears to be melted, nor can I find anything that smells fried. Now my car just goes, click, click, click....everytime I turn the key.  I still get a switched 12v to the wire I ran for the SR200.
I am open to suggestions as to where to look.
Posted: December 26, 2004 at 9:52 AM / IP Logged
Use your DMM to test all the fuses under the hood and all the fuses in the dash/glovebox.
blaube
Member - Posts: 17
Posted: December 26, 2004 at 10:10 AM / IP Logged
Where else should I check if I were to find none of the fuses blew and I still have 12v constant, switched, etc?
Posted: December 26, 2004 at 11:07 PM / IP Logged
Check to make sure that your getting 12 volts on the starter wire ( YELLOW )
blaube
Member - Posts: 17
Posted: December 27, 2004 at 4:22 PM / IP Logged
Thanks for the support.
I checked all the fuses and found them all to be good. I still have 12volts everywhere, both switched and constant. I also placed a screwdriver between the contacts of my starter to see if it would spark or even try to start and did not get a response. I am assuming I may have fried the starter. I have not checked any fuseable links because I cannot find any.
The next morning I remembered I had forgotten to take my charger off the battery before I tried to start it.. I had it on a 10 amp charge. Could that be a reason I smoked something?
-Brent
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
