crimestopper 2005 trunk
hot00boy
Member - Posts: 37
Posted: December 26, 2004 at 12:20 AM / IP Logged
Hello,
I have a 1993 Buick Roadmaster that I've installed a Crimestopper 2005fm on.  I have everything else hooked up except the trunk pin switch and the trunk release on the auxilary channel.  My question is what colors would the trunk pin switch and the trunk release wires be inside the car and also their locations.
Thanks in advance
John
Moderator - Posts: 12,488
Posted: December 26, 2004 at 12:23 AM / IP Logged
TRNK/HTCH RELEASE|black               |+  |at switch
Trunk Trigger is a DARK GREEN (-) going to the back of the car in the driver's kick panel or it's the BLACK/ ORANGE (-) at the light.
hot00boy
Member - Posts: 37
Posted: December 26, 2004 at 12:30 AM / IP Logged
the trunk release is black at what switch?
Posted: December 26, 2004 at 9:45 AM / IP Logged
yup
geepherder
Platinum - Posts: 3,668
Posted: December 27, 2004 at 9:46 PM / IP Logged
He meant at the trunk release switch.  You may have to rip out some interior paneling, but that's probably the easiest way to get it.
hot00boy
Member - Posts: 37
Posted: December 27, 2004 at 10:07 PM / IP Logged
The dark green wire running to the back of the car did not go to the trunk pin switch.  It is also not negative.  Any other suggestions?
hot00boy
Member - Posts: 37
Posted: December 27, 2004 at 10:40 PM / IP Logged
i just went out and checked out the ORANGE / black wire and it was positively charged.
Saturday, August 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
