Easier Tach Wire
malucyk
Copper - Posts: 56
Posted: October 18, 2002 at 2:38 PM / IP Logged
I am installing a car starter into a 1993 Chevrolet Astro Van
My sheet says to find a white wire form the distributor. This easier said then done as that crappy engine cover inside the van is almost impossible to remove. Is there any source near the front of the engine I could tap into???
Matt
kirk50
Posted: October 18, 2002 at 3:43 PM / IP Logged
that year should have a test plug on the fire wall or under air cleaner with white wire you should be able to get it there.  hope this helps
kirk
kirk
