wiring problem with a 2002 lancer
evergrin9904
Member - Posts: 9
Posted: December 28, 2004 at 7:04 AM / IP Logged
Hey guys i was wondering if anyone could offer me any help.  Im installing a remote start and keyless entry on a 2002 mitsubishi lancer and im having trouble with the starting. Any wiring diagram does not show an ignition 2 wire so i did not hook it up. Now it cranks over but it does not start. Ive increased the cranking time to six sec. but still nothing. It still starts fine with the key, within 2 secs. It also will unlock the doors but will not lock them I hooked the lock up to the purple wire and unlock to the lt green wire. Just stuck on what to do any help would be greatly appreicated thanks.
evergrin9904
KarTuneMan
Platinum - Posts: 7,056
Posted: December 30, 2004 at 11:09 PM / IP Logged
12volts white  +  ignition harness
Starter BLACK / YELLOW  +  ignition harness
Second Starter N/A
Ignition BLACK/ white  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue/black  +  ignition harness
Second Accessory blue/white  +  ignition harness
Notes: Not required for remote start.
Keysense blue    ignition harness
Notes: The wire rests at ground with the key out of the ignition cylinder, and goes to an open circuit when the key is inserted.
Power Lock purple  -  driver kick, door harness
Power Unlock lt. green  -  driver kick, door harness
Lock Motor blue/red  5wi driver kick, door harness
Unlock Motor white  5wi driver kick, door harness
Parking Lights+ grn/yel (L), grn/wht (R)  +  wht plug bottom of fuse box
Parking Lights- N/A
Hazards white  -  hazard switch
Turn Signal(L) lt. green or WHITE/ blue  +  driver kick, harness to rear
Turn Signal(R) yellow  +  driver kick, harness to rear
Reverse Light brown  +  driver kick, harness to rear
Door Trigger white  -  wht plug bottom of fuse box
Dome Supervision use door trigger
Trunk/Hatch Pin GREEN/ orange  -  light in trunk
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm gray  -  driver kick, door harness
Disarm No Unlock N/A
Tachometer BLACK / YELLOW or BLACK/ green  ac  either ignition coil
Wait to start N/A
Brake Wire green  +  brake pedal switch
Parking Brake blue/red  -  parking brake switch
Horn Trigger yellow  -  steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
wiring problem with a 2002 lancer - Last Post -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
KarTuneMan
Posted: December 30, 2004 at 11:12 PM / IP Logged
Check your tach wire....!! Can you put the unit into continuos run, you know set the remote start, pull out the key and keep it running?  If you can, check your ign. and acc. connections
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
