1998 Chevrolet Cavalier - VSS Wire
honl
Posted: January 18, 2005 at 11:33 PM / IP Logged
Read the forum and got the info for where the wire is and what color it is, but there are doubles of the wire that it says. The forum says "VSS Lead GREEN / WHITE PCM, under Passenger's Fender, Black Connector Pin 16 " There is no black connector.
It looks like a fuse box, and the one side is an input and the other possibly an output. Except that it isn't a fuse box.
Any experts on this topic?
Also what does PCM stand for?
Email me at bahonl@hotmail.com
vk3hau
Member - Posts: 8
Posted: January 19, 2005 at 5:59 AM / IP Logged
PCM = Powertrain Control Module
Location = Behind dash, passenger side
sorry , but this is all I know. hope it helps in same way.
cheers and beers from sunny Sale, Vic. AUS.
1998 Chevrolet Cavalier - VSS Wire - Last Post -- posted image.
sparkie
Platinum - Posts: 2,061
Posted: January 30, 2005 at 1:03 PM / IP Logged
There are two places to find the wire fairly easily. First is in the radio's power plug. It is the GREEN / WHITE wire. If your car came equipped with a radio that has speed control volume it will be in the plug. Otherwise, you can find it in the bottom side of the large plug next to the driver's side shock tower in the engine compartment. You will need to remove the air filter box to get to it. The GREEN / WHITE wire is only in the bottom side of the plug. The wire dead ends there and doesn't come through the top side of the plug. It is very close to the corner of the plug that is easiest to get to.
sparky
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
