VW Touareg VSS wire
lasd
Posted: January 22, 2005 at 9:06 PM / IP Logged
Does anyone know where I can find the VSS on a 04 Touareg with factory navigation. I changed out the factory navigation with a Kenwood and I can't locate the VSS. Thanks in advance!
jazzy95tsi
Member - Posts: 36
Posted: January 25, 2005 at 2:45 PM / IP Logged
Good Luck, that signal is ONLY available as databus info directly from the control modules that are the wheel speed sensors.  Sorry manVW Touareg VSS wire - Last Post -- posted image.
Jeff VW Touareg VSS wire - Last Post -- posted image.
lasd
Posted: January 25, 2005 at 5:34 PM / IP Logged
Thanks for the reply. That's what I've been finding too... I tried to test the speed sensors at the wheels but didn't get the right signal. I guess I need to buy some kind of aftermarket speed sensor to generate the proper signal the Kenwood Nav needs.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
