Remote/Ant. wire from deck isnt working
shesaidshewas18
Copper - Posts: 96
Posted: January 28, 2005 at 1:59 AM / IP Logged
I think I damaged the pin for this wire.. Anyways, I was just wondering if it was ok to use the switched 12v wire from the deck, and maybe tap a remote wire for my amp instead of using the remote wire from the deck? Does that make any sense?!
godd dan it
Copper - Posts: 447
Posted: January 28, 2005 at 4:41 AM / IP Logged
Im not sure if this will work, but try using the ACC. wire. That way the amp wont be on all time. It will only be on when the ignition is on.
Teamrf
Gold - Posts: 1,031
Posted: January 28, 2005 at 8:45 AM / IP Logged
Yes, you can tap into the red wire on the back of the radio it will have power with the car on, and an open circuit with the car off.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
