need starter diagram for 2001navigator
d_arnold
Copper - Posts: 59
Posted: January 29, 2005 at 10:31 AM / IP Logged
Hey, I'm looking for a wire diagram for a 2001 lincoln navigator. I found the 2000 in the vehicle database but not the 01. are they the same? or can someone post a 01 wire guide for the lincoln navigator.
Thanks so much.
Teamrf
Gold - Posts: 1,031
Posted: January 29, 2005 at 1:41 PM / IP Logged
12volts yellow, grn/purple   +  ignition harness
Starter RED / lt. blue   +  ignition harness
Second Starter
Ignition blue/lt. green   +  ignition harness
Second Ignition gray / YELLOW(2nd acc)   +  ignition harness
Third Ignition
Accessory RED / black   +  ignition harness
Second Accessory BLACK/ green   +  ignition harness
Keysense
Power Lock pink / YELLOW   -  keyless module
Notes: The keyless module is located high in the drivers kick against the firewall.
Power Unlock pink/green   -  keyless module
Notes: The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to *wake-up* the system refer to directfax document #1093.
Lock Motor pink/black    drivers kick panel
Unlock Motor RED / orange    drivers kick panel
Parking Lights+ brown    at light switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. blue/white   -  keyless module
Notes: One of two. The wire is in pin 11 and it is next to the BLACK/ pink wire. Test with a digital multi-meter ONLY, to keep from damaging the circuit tied into the other lt. blue/white. For individual door trigger wires, the LF door is BLACK / YELLOW, the RF door is BLACK/ pink, the LR door is BLACK/ lt. blue, and the RR door is BLACK/ white. They are all negative and are at the GEM module, which is attached to the fuse box.
Dome Supervision BLACK/ lt. blue   +  passenger kick panel
Trunk/Hatch Pin tied in with door
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer
Notes: Find tach at the coils on top of the valve cover on the driver side of the motor. Remove 2 bolts and slide the cover off. Use GREEN/ YELLOW on the first cylinder for tach. Can also use fuel injectors for tach, use any of the wires that is not red.
Wait to start
Brake Wire green   +  at brake switch
Parking Brake
Horn Trigger dk. blue   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
need starter diagram for 2001navigator - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: PATSPart #: 555P, 555F, 556U, or 555U
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
