2005 Toyota Corolla S Alarm/Remote Start Wiring
zeidouni
Member - Posts: 7
Posted: February 08, 2005 at 5:43 AM / IP Logged
Would anyone have the alarm wiring diagram for a 2005 Toyota Corolla S ?  I need this to put in a remote starter.
Your help will be greatly appreciated.
dare_ds69
Silver - Posts: 419
Posted: February 08, 2005 at 6:40 AM / IP Logged
12volts white (25A), black (15A)  +  ignition harness
Starter red  +  ignition harness
Second Starter N/A
Ignition BLACK/ white  +  ignition harness
Second Ignition BLACK / YELLOW  +  ignition harness
Third Ignition N/A
Accessory blue/red  +  ignition harness
Second Accessory N/A
Keysense blue/black  -  ignition harness
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lock green  -  driver kick, 10 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlock blue / YELLOW (double pulse)  -  driver kick, 10 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/black (-) in the passenger kick in a 10 pin plug.
Lock Motor blue  5wi driver kick, blue 12 pin plug
Unlock Motor red  5wi driver kick, blue 12 pin plug
Parking Lights+ green  +  driver kick, harness to rear
Parking Lights- GREEN / WHITE  -  headlight switch
Hazards yellow/black  -  flasher relay left of fuse box
Turn Signal(L) GREEN/ black  +  flasher relay left of fuse box
Turn Signal(R) GREEN/ YELLOW  +  flasher relay left of fuse box
Reverse Light RED / black  +  front of fuse box, 10 pin plug
Door Trigger RED / white  -  interior light switch on dash
Dome Supervision RED / black  -  interior light switch on dash
Trunk/Hatch Pin RED / white  -  light in trunk
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black  ac  ECM, far right plug, pin 5
Notes: The ECM (Engine Control Module) is behind the glove box.
On the XRS models, the tach wire is in the second plug from the right, pin 3.
Wait to start N/A
Brake Wire GREEN / WHITE  +  brake pedal switch
Parking Brake RED / black  -  parking brake switch
Horn Trigger GREEN/ YELLOW  -  steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2005 Toyota Corolla S Alarm/Remote Start Wiring - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: TransponderPart #: 556U or 555U
Notes: Standard on all models
how own your mind, control your life.
MECP certified. always use a DMM
zeidouni
Member - Posts: 7
Posted: February 17, 2005 at 3:55 PM / IP Logged
thank you so much.
2000civic
Member - Posts: 15
Posted: April 23, 2005 at 2:40 AM / IP Logged
I am about to do an install on my friends new Corolla-S and was wondering if there are any onther hints for me.  Thanks for the great info so far!
Platinum - Posts: 12,488
Posted: April 23, 2005 at 8:53 AM / IP Logged
Use the 2005 Toyota Corolla S Alarm/Remote Start Wiring - Last Post -- posted image.Search  button for other helpful hints for this car.
nava94
Silver - Posts: 296
Posted: April 23, 2005 at 12:04 PM / IP Logged
the door trigger you could get it at the driver kick going up to the apillar you will find a small wire loom that is were you could get your door trigger. your trunk trigger is also there or else at the driver kick panel.
