Turn +12volt on only when ignition off
Newtyp
Posted: February 15, 2005 at 8:58 AM / IP Logged
Hello,
I believe that this would be possible, but I am completely dumbfounded on how to wire it together. Please advise.
I am trying to have a relay or maybe there is something else that can do the trick that could be recommended that turn a lead into +12volts once the car ignition is turned off. Similar to the VARAD Led alarm lights, once the ignition is turned off the lights flash.
I tried to search on the forum but have had no luck. I am trying to wire a shock sensor for my fathers Acura TL due to the increased HID thefts in the area however I do not want the shock sensor to be on at all times, only when the car is off. Please advise.
Ken
Platinum - Posts: 12,488
Posted: February 15, 2005 at 11:14 AM / IP Logged
Use a relay SPDT :
  • 86: Ground
  • 85: 12 volts switched
  • 87: NOT USED
  • 87a: 12 volts constant
  • 30: This will go to the (+) side of the device that you want to have turn on when ignition is OFF
Newtyp
Posted: February 15, 2005 at 11:17 AM / IP Logged
Jeff,
Thank you for the FYI. I will give it a try later today.
My best regards.
Ken
hotwaterwizard
Silver - Posts: 1,350
Posted: February 19, 2005 at 12:36 AM / IP Logged
Here is a drawing of the Relay inside view and connections.
Turn +12volt on only when ignition off - Last Post -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
