2 quick questions
boardinbum
Silver - Posts: 358
Posted: February 23, 2005 at 11:48 PM / IP Logged
Sorry about the repost. The first thread got mixed up...
First, I'm in a tight space, and was wondering if I should go with an Alpine Type-E SWE-1041 (10") and put it in a 1 cu.ft. ported box or a Alpine Type-E SWE-1241 (12") and put it in a 0.85 cu.ft. sealed box. I'm looking for some nice, deep boom.
Also, is it possible to use a 2 channel amp on a svc sub?
stevdart
Platinum - Posts: 5,816
Posted: February 24, 2005 at 2:25 PM / IP Logged
Listen to both subs at your local dealer and pick the one you like best....if it is spec'd to go into a sealed enclosure of that size.  Yes, you can use a two-channel amp to power any speaker or combination of speakers as long as the impedance load is comfortable for the amp to handle.  Your SVC sub should be 4 ohms or 8 ohms to be bridged across the two channels.
boardinbum
Silver - Posts: 358
Posted: February 25, 2005 at 10:49 AM / IP Logged
The sub is 4ohms. So with a 2 channel amp, would I just run to positive wires and 2 negative wires to it? or what?
stevdart
Posted: February 25, 2005 at 11:06 AM / IP Logged
Look at the diagram in your amp manual for 'bridged' configuration.  It is one pos and one neg from the speaker terminals to the bridged terminals of the amp.
