Fuel pump relay
wsu1
Posted: March 01, 2005 at 8:41 PM / IP Logged
I have a 1991 Nissan Pathfinder/Terrano with Z24 petrol engine
Plan to add in a fuel pump cut-out  hidden switch as an anti-theft measure. Anyone know where is the fuel pump relay ?
What about the related wire harness ? where would be the best location to cut the circuit for my hidden switch ?
Have done a search, but seems that none covers the fuel pump harness. Would be great if someone has the wiring details.
Any info available is very much appreciated.
secureauto
Copper - Posts: 197
Posted: March 03, 2005 at 2:19 AM / IP Logged
I couldnt find any info on it either, Have you tried looking at the fusebox under the hood? There might be a relay for the fuel pump.
ASE Certified
wsu1
Posted: March 03, 2005 at 9:31 PM / IP Logged
There is no fusebox found under the hood.
I did tried to take a look at the fusebox under the driver's meter panel. Not so easy to access those bunch of wires hiding underneath. A few relays were also found inside the panel next to the tail light. Not sure for what exact functions.
Open up the cover for the in-tank fuel pump. It has 4 wires connection there.  1 or 2 are used for the fuel gauge, i believe. Not sure it has single or dual flow rate pump. Any idea ?
Might need to spend a weekend searching for the right wires/relay  if no information is readily available here.
