Two Switches to One Relay?
Gsrpwr704
Posted: March 03, 2005 at 9:58 AM / IP Logged
Hey guys, I was wondering if it is possible to wire a relay with two switches so if I was to flip one switch to turn something off, then I can go to the other switch to turn it back on. It would be kinda like a switch at the bottom of a stairway and a switch at the top. So that you can turn the light on and off from either upstairs or downstairs.
Any help would be greatly appreciated
ff-mike
Copper - Posts: 199
Posted: March 04, 2005 at 2:03 PM / IP Logged
Very easy to do
You would need 2 spdt switches. Connect the outer 2 terminals on the switches to each other. The middle terminal on switch 1 goes to power, the middle terminal on switch 2 goes to the load
