2004 chevy avalanche
slimcox
Member - Posts: 6
Posted: March 10, 2005 at 8:44 PM / IP Logged
I'm looking for the wiring diagram for this vehicle can anyone help me.
ecox
thepencil
Gold - Posts: 1,526
Posted: March 10, 2005 at 11:11 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / AVALANCHE / 2004 / Remote Start
12volts red & RED / white   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition white   +   ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Power Lock use 457G or 456G module
Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601.
Power Unlock see power lock
Lock Motor gray      driver door module in door
Unlock Motor tan      driver door module in door
Parking Lights+ brown   +   driver kick panel
Parking Lights- gray/black   -   switch or BCM, brown plug pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white   -   steering column
Turn Signal(L) green   +   steering column
Turn Signal(R) lt. green   +   steering column
Reverse Light lt. green   +   BCM, black plug, pin F
Door Trigger see notes   -   see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each.
Dome Supervision gray/black   +   BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green   -   driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white   ac   instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start N/A
Brake Wire white   +   brake pedal switch
Parking Brake lt. blue   -   switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black   -   column or BCM, gray plug, pin B9
Memory Seat 1 red   +   driver door module in door
Memory Seat 2 pink   +   driver door module in door
Memory Seat 3 N/A   +
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 457G, 555L, or 555T
Notes: The Passlock 2 wire colors are yellow, black (org/blk), and RED / white (not used).
Be careful whose advice you buy, but be patient with those who supply it.2004 chevy avalanche - Last Post -- posted image.
slimcox
Member - Posts: 6
Posted: March 11, 2005 at 1:35 PM / IP Logged
thanks.
ecox
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
