Honda CRV 2002 EX alarm wiring diagram
zeidouni
Member - Posts: 7
Posted: April 01, 2005 at 2:37 PM / IP Logged
Could anyone please provide me with a security system / remote starter wiring diagram for a 2002 Honda CRV Ex.
Thanks in advance.
dare_ds69
Silver - Posts: 419
Posted: April 01, 2005 at 5:45 PM / IP Logged
12volts white  +  ignition harness
Starter BLACK/ white  +  ignition harness
Second Starter N/A
Ignition BLACK / YELLOW  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red  +  ignition harness
Second Accessory WHITE/ red  +  ignition harness
Keysense RED / white  -  ignition harness
Power Lock WHITE/ blue  -  gray plug above driver kick
Power Unlock WHITE/ green  -  gray plug above driver kick
Lock Motor yellow/black  5wi gray plug above driver kick
Unlock Motor YELLOW /GREEN  5wi gray plug above driver kick
Parking Lights+ RED / black  +  driver kick panel
Parking Lights- blue  -  factory alarm plug
Notes: The factory alarm plug is a green plug to the left of the steering column.
Hazards same as turn signals
Turn Signal(L) GREEN/ red  +  steering column
Turn Signal(R) GREEN/ YELLOW  +  steering column
Reverse Light GREEN/ black  +  fuse box, 18 pin plug, pin 1
Door Trigger green & lt. GREEN/ red  -  factory alarm plug
The drivers door trigger is green, and lt GREEN/ red catches all the other doors. Use both and diode isolate each.
Dome Supervision comes on with unlock
Trunk/Hatch Pin GREEN / WHITE & red  -  factory alarm plug
Notes: The GREEN / WHITE is for the hatch glass pin switch, and the red is for the tailgate pin switch.
Hood Pin yellow/red  -  factory alarm plug
Trunk/Hatch Release BLACK / YELLOW  -  gray plug above driver kick
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue  ac  test connector
Notes: The test connector is next to the battery.
Wait to start N/A
Brake Wire WHITE/ black  +  brake pedal switch
Parking Brake GREEN/ orange  -  parking brake switch
Horn Trigger orange  -  factory alarm plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Honda CRV 2002 EX alarm wiring diagram - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: TransponderPart #: 555i, 556U, or 555U
Notes: N/A
how own your mind, control your life.
MECP certified. always use a DMM
zeidouni
Member - Posts: 7
Posted: April 04, 2005 at 10:23 AM / IP Logged
thank you very much, I really appreciate it.
