Extend Battery cable?
1883atlantics
Member - Posts: 41
Posted: April 13, 2005 at 5:20 PM / IP Logged
How can I extend my +12V 6 AWG battery cable? In my van, the OEM pos. cable is connected to the engine harness (go Chrysler, great design) so replacing the cable is not possible (for less than $1,000). How can I extend the cable? It's getting old and I don't want it to fail on me, plus I want to add some reliable (gold, etc) battery posts as well. I was thinking I could add a simple distro block and run a large gauge wire from the battery, but is there a simpler connector I could use? Do they even make 6 AWG butt connectors? If so,  wouldn't crimping those be a pain or require a special tool ($)? If anyone can help, I'd appreciate it. Thanks
ps. it's a 96 Plymouth Grand Voyager (3.3L V6)
TruckSystem
Copper - Posts: 185
Posted: April 14, 2005 at 1:37 PM / IP Logged
They make butt connectors that big, when I was doing mechanic work on semis we had plenty of larger sizes around the shop. As far as crimping it, if you can somehow get that cable out of the engine compartment for a second just take a vice to it or set it on a piece of wood or something and beat the hell out of it with a hammer, both methods, while rudimentary, make great crimps. If you can't find one at a local store check around at a semi part dealership. Also you could solder it together and tape it up real well as an alternative.
2003 Chevrolet Silverado Standard Cab ~ Alpine CDA-9851
Diamond Audio D3600.1 ~ 2x Diamond Audio TM310D4
Diamond Audio D3400.4 ~ Diamond Audio Hex S600s
AstroStart RS5204 Remote Start/Alarm
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
